Fiberglassin Plastic
dray504
Member - Posts: 15
Posted: April 01, 2005 at 10:19 AM / IP Logged
hey i have  a 99 accord that im wanting to fiberglass the door panels, the panels are like a hard plastic once u rip the vinyl and foam stuff off, i've heard differnt opinions on making fiberglass resin stick to the plastic, as far as roughing the plastic up or using kitty hair or a differnt substance on the plastic first to allow the fiberglass to stick, whats the best method and whats worked for everybody on fiberglassin plastic, THZ!!
please respond ASAP
ravenndude
Silver - Posts: 250
Posted: April 01, 2005 at 10:32 AM / IP Logged
someone said to drill holes in the plastic and make sure you get some glass in there and the resin soaks through. Kinda aks like a FG screw.
I never tried it personally though
dray504
Member - Posts: 15
Posted: April 01, 2005 at 10:36 AM / IP Logged
with drilling holes in the plastic do yall mean to drill str8 though the plastic or to drill like half way??? how far apart should the holes be??? will ruffing the plastic up be enough or any other methods????
THZ!!!
oonikfraleyoo
Gold - Posts: 1,069
Posted: April 01, 2005 at 12:50 PM / IP Logged
Drilling all the way thru is the only reliable method I've tried. Suffing it up usually doesn't work. Resin dosen't like to stick to plastic at all.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
dray504
Member - Posts: 15
Posted: April 01, 2005 at 2:05 PM / IP Logged
ive been reading aliitle bit about fiberglassing plastic nad see some people use some typr of bondo-glass from like walmart, is that what its called??? is it regular bondo?? also i se people use kitty hair and that it sticks well to plastic, does that work good??? how much does kitty hair cost and what size container?? also i see some people use duramix, and it sticks well to plastic, i see duramix comes in differnt part numbers (4040, 4050, etc.), which one should use??? can u get kitty hair or duramix from walmart or u have to go to a paint shop. THZ
Alpine Guy
Platinum - Posts: 2,478
Posted: April 01, 2005 at 2:54 PM / IP Logged
In the past i have drilled a crap load of 1/16 holes, and sanded with like 30 grit.
dray504
Member - Posts: 15
Posted: April 02, 2005 at 8:43 AM / IP Logged
i scruffed up  a section of the plastic and put some resin on that area to test it out, and it seems to hold up pretty good, it only comes off if i really stab at it, so i think it will be ok.
