1996 honda civic alarm
Welcome Guest :)
cisco
Member -
Posted: November 10, 2002 at 11:42 AM / IP Logged
does anyone have a wiring diagrahm for a 1996-1998 honda civic?
Platinum -
Posted: November 10, 2002 at 11:50 AM / IP Logged
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness || STARTER|BLACK/ white |+ |ignition harness || IGNITION|BLACK / YELLOW |+ |ignition harness || SECOND IGNITION|yellow |+ |ignition harness || ACCESSORY|WHITE/ black |+ |ignition harness || POWER LOCK|GREEN / WHITE |- |blue plug dkp or *2 || POWER UNLOCK|GREEN/ orange*3 |- |blue plug dkp or *2 || PARKING LIGHTS +|RED / black | |dkp/fuse box or *4 || PARKING LIGHTS -| | | || HEADLIGHTS|RED / wht(L)RED / blu(H)|+ |steering column || DOOR TRIGGER|lt. GREEN/ red*5 |- |factory alarm plug*2 || TRUNK/HATCH PIN|blue/blk*6 |- |dkp, harness to rear || HOOD PIN| | | ||TRNK/HTCH RELEASE| | | || FCTRY ALARM ARM| | | ||FCTRY ALRM DISARM| | | || TACHOMETER|blue | |test connector*1 || BRAKE WIRE|GREEN / WHITE |+ |brake switch || HORN TRIGGER|gray or blue |- |column or*2 || WIPERS|blue and blue / YELLOW|- |steering column || LF WINDOW UP/DN|RED / yellow - RED / blu|A |drivers door || RF WINDOW UP/DN|blue/yel - blue/org |A |drivers kick panel || LR WINDOW UP/DN|grn/yel - green |A |dkp, harness to rear || RR WINDOW UP/DN|yellow - yellow/grn |A |dkp, harness to rear |Notes:
*1 Drivers side fire wall under hood. *2 Factory alarm plug located behind radio. (GREEN/ plug). *3 Can also use blue / YELLOW for driver door unlock only. *4 Male blade terminal at fuse box. Also at the back of the dimmer switch. *5 Can also be found in a light green plug above the fuse box or bottom of drivers kick, harness to rear. For dome supervision use lt. GREEN/ black at factory alarm/keyless plug. *6 Also available at factory alarm plug. (lt. green).Jeff
toddbenson
Member -
Posted: November 16, 2002 at 1:22 AM / IP Logged
Hey Jeff i put a stereo in a 96 civic. where does the green plug go? cause now my factory door locks wont activate though the remote and the dome light wont work. anything would help. thanks
Platinum -
Posted: November 16, 2002 at 4:51 PM / IP Logged
Did you use a wiring harness or did you cut off the plug at the radio ? Here is a link to a CD installation of the deck:
http://www.installdr.com/InstallDocs/Honda/PDF/466013.pdf Jeff
Thursday, April 16, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
