98 dodge neon rt, stellar 8000
Bagd98rt
Posted: April 02, 2005 at 3:57 PM / IP Logged
i'm installing a stellar 8000 in my 98 dodge neon rt i got everything done but cant figure out the triggers if some one can tell me how to do that part all i have left is a brown and a white wire please help me!!!!!!!!     http://www.stellaralarms.com/files/ST8000.pdfnd
mo12v
Posted: April 02, 2005 at 6:47 PM / IP Logged
Should be.......   http://www.stellaralarms.com/files/ST8000.pdf
U would only use BROWN Wire if it is NEGATIVE PIN Switch
U would only use WHITE Wire if it is POSITIVE PIN Switch
YELLOW (-)AT ANY PIN SWITCH *
* YELLOW (-) Wire Is Also Located In A GRAY 20 Pin Connector Behind The Driver Dash.
MO
