Alpine Illumination
vette00057
Member - Posts: 7
Posted: April 02, 2005 at 11:41 PM / IP Logged
Hi all, I just installed an alpine cda-9827 in my 1995 mustang and am having trouble figuring out how to connect the wires on my harness to make the illumination on the display dim when i turn my headlights on.  My factory radio used to do this.   The alpine harness has an illumination wire and the ford harness has a (-) dimmer wire and a (+) dimmer wire.  Any ideas?  Thanks!
Bucko
Posted: April 03, 2005 at 1:01 AM / IP Logged
Similar problem with my Alpine installation...question: is there 12 volts coming off of the (+)dimmer wire when you take it to a common ground? (use a digital meter!)
Question to the forum:
If so, is that the wire you hook into?
I'm just wondering if blasting 12v into the illumination lead is what powers the dimming function...(just worried about frying something...)
thx1138
tcss
Silver - Posts: 1,623
Posted: April 03, 2005 at 2:16 PM / IP Logged
It's 12 volt pos. for all Alpine HU. Should be lite blue with red stripe on your ford harness.
vette00057
Member - Posts: 7
Posted: April 05, 2005 at 10:41 PM / IP Logged
i have not yet had time to hook up my multi meter to the (+) dimmer wire to see if there its 12V.  but here is what i have tried;  i attached the (+) dimmer to the illumination wire and that didn't work, i then attached the (-) dimmer to a ground with the (+) dimmer and illumination still attached and still didn't work,  then i attached the illumination to a 12V constant and that didn't cause the HU dim.
my ford harness doesn't have a lite blue with red stripe wire on it, it has a (+) dimmer wire and a (-) dimmer wire on it but i don't remember what the colors are.
i am supposed to be able make the HU dimm when my lights are turned on with this model HU right?
any more suggestion?  thanks for your input guys.
