Sunroof module for 93 Prelude ??
Thinkster
Copper - Posts: 94
Posted: April 30, 2002 at 4:13 AM / IP Logged
Already installed window module for both windows to roll up upon Arming alarm,  but customer wants The sunroof to also close when alarm is armed.  I know, use a window module.   I did this, but it seems the motor for the sunroof has some sort of clutch mechanism or something so the motor still sounds like it is turning even though the sunroof is fully closed.   Since the motor keeps running, it does not pull enough current for the Window module to trigger STOP.    So does anyone have a schematic for these common generic window modules Or even a patent number?   I'd like to mod it to make it more sensitive to current draw.   Or does someone have a better solution.   It's not the module,  I've already tried 3 different ones.    I'd like to find a simple solution without having to build a one-shot timer circuit into the module.
Platinum - Posts: 12,488
Posted: April 30, 2002 at 5:24 AM / IP Logged
We use a generic brand module and we have installe dit into may Honda sunroofs and no problems. What brands have you tried ?
Thinkster
Copper - Posts: 94
Posted: May 01, 2002 at 1:17 AM / IP Logged
The only ones I stock are the ones with no brand name on them and are in a black plastic case with the diagram stamped on the back of the plastic.  Although I have tried "different" brands of these,  they all look the same, just the cardboard packaging is different.
Posted: May 01, 2002 at 5:17 AM / IP Logged
The ones that I have are about the same as yours except that the wiring instructions are on the packaging as well as the casing .
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
