1988 Cutlass Supreme, Car Stereo
Lilrogers2003
Posted: April 09, 2005 at 5:09 PM / IP Logged
I have 1988 Oldsmobile Cutlass Supreme. I bought a cd player for my car. I wired everything up properly and turned the system on. It played for like 5 minutes but i forgot to put electric tapes over the wires so a spark shot and my cd player system shut off and wont work. I bought a new fuse and a new cd player but still wont work. Can wires blow.
tcss
Silver - Posts: 1,623
Posted: April 09, 2005 at 5:17 PM / IP Logged
You most likely have 2 differant fuses for the stereo. One will be labeled "radio" and that contols the switched or accessory power lead. The constant 12 volt lead is usually hooked into the "cig. lighter" fuse on older GM cars. ALWAYS insulate all wires before powering up.
Lilrogers2003
Posted: April 09, 2005 at 5:19 PM / IP Logged
so what would you recommend i do
tcss
Posted: April 09, 2005 at 5:22 PM / IP Logged
The "cig lighter" fuse is most likely blown. Find it and replace it.
Lilrogers2003
Posted: April 09, 2005 at 5:23 PM / IP Logged
how would i replace a cig lighter fuse
tcss
Posted: April 09, 2005 at 5:35 PM / IP Logged
Go to the fuse block, look for the fuse labeled " cig lighter" pull this fuse out and replace it with one with the same amp rating.
Lilrogers2003
Posted: April 09, 2005 at 5:55 PM / IP Logged
fuse block or box
tcss
Posted: April 09, 2005 at 5:59 PM / IP Logged
Block, under the drivers side dash. Is anyone else watching this?
Lilrogers2003
Posted: April 09, 2005 at 7:01 PM / IP Logged
Alright my fuse block is in my glove department but i dont see anything that says cig. liter please help.
boardinbum
Silver - Posts: 358
Posted: April 09, 2005 at 7:54 PM / IP Logged
Hahah, yeah, I'm watchin' it.
This happened to me, actually. On my first attempt at a cd player install. It turned out it blew the whole cd player.
Tuesday, September 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
