Limited Menu on Kenwood Navigation
dayking
Posted: April 19, 2005 at 12:10 AM / IP Logged
Currently I own a Kenwood KNA-DV2100 connected to a 915DVD that is about to be replaced with a KNA-DV4100. My main annoyance is that the menu on the navigation is severly limited while driving. Usually my girlfriend is operating the navigation anyway.
Is there a way to allow the normal use of navigation while allowing all of the menu functions? (ie disconnecting from the e-brake) I understand that disconnecting the VSS will cause problems w/ the navigation.
auex
Platinum - Posts: 5,041
Posted: April 19, 2005 at 9:45 AM / IP Logged
Pull over and push the ebrake down. Then you will have full use of nav and can watch viceo.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
oonikfraleyoo
Gold - Posts: 1,069
Posted: April 19, 2005 at 11:00 AM / IP Logged
Depending on your car, you may need to pull the ebrake up.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
auex
Posted: April 19, 2005 at 3:35 PM / IP Logged
Why, I didn't even think about it that way.   True none the less.
Cali_pilot
Copper - Posts: 73
Posted: April 20, 2005 at 12:33 AM / IP Logged
While auex and oonikfraleyoo's suggestion will yield very effective results, you can also disconnect the e-brake lockout wire from the e-brake and hook it up to a switch for temporary use or just ground it permanently to have all menu options available.  Of course I am not telling you this so you can watch DVDs or mess with Navi while driving but instead for your wife to do the Navi while you keep your eyes on the road.
2011 Ford F-150 Super-Crew FX4
HU: Pioneer AVIC-Z1
Fronts: Infinity Kappa 682.9cf
Rears: Infinity Kappa 682.9cf
Amp: Profile AP1040
Sub: Pioneer TS-SWX251
Dsteinmann
Copper - Posts: 75
Posted: April 22, 2005 at 12:36 AM / IP Logged
I have the 4100 Just hook up the VSS Wire and Ground the EBrake Wire and i have fully menus all the time the thing doesent even know what a brake is mine says im going 80mph with the E Brake on
Kapone
Posted: May 14, 2005 at 12:01 PM / IP Logged
All of the replies on here are correct, but if you are referring to menu that appears at the bottom of the screen, in regards to your Navi functions, then you need to calibrate the system.  I received this information directly from Kenwood.  If your functions are not working when you are in motion, like the other installers said, you need to ground the Parking Lead out or hookup a switch
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
