car with multiple 12 constant wire
Reeceddogg
Copper - Posts: 331
Posted: April 19, 2005 at 7:12 PM / IP Logged
on cars that have multiple how do you deceide on what wire to use for remote start applications, my 03 taurus has 4 of these wires but the alarm only has 2 outputs. should i use a relay for the other two?
mo12v
Posted: April 19, 2005 at 7:25 PM / IP Logged
If you are asking about the wires at the Ignition Switch On your Taurus:
Usually those wires terminate together in the loom, Junction Box / Fuse Box or elswhere
You just need to be concerned if the wires in question will carry the added load of your RS....................which they will.
On some Vehicles U have to use a Constant from the Battery because the Switch wires or Fuse Block does not carry sufficient Power
MO
thepencil
Gold - Posts: 1,526
Posted: April 20, 2005 at 10:33 AM / IP Logged
Additional note to the above post.
If you are putting in an alarm or starter. The constant wire that you should be concern about is the GREEN/ purle wire at the ignition harness. It's the one that can carry the load when you are putting in an alarm and starter.   Below is the wiring diagram for your vechile.
DIRECTWIRE™ WIRING INFORMATION - FORD / TAURUS / 2003 / Remote Start
12volts lt. GREEN/ purple   +   ignition harness
Starter RED / lt. blue   +   ignition harness
Second Starter N/A
Ignition RED / lt. green   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW   +   ignition harness
Second Accessory BLACK/ lt. green   +   ignition harness
Keysense
Power Lock pink / YELLOW   -   26 pin plug @ GEM
Notes: The GEM (Generic Electronic Module) is to the left of the steering column.
Power Unlock pink/lt. green   -   26 pin plug @ GEM
Lock Motor pink/black   5wi top plug of fuse box
Unlock Motor RED / white   5wi top plug of fuse box
Parking Lights+ brown   +   headlight switch or fusebox
Parking Lights- N/A
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light BLACK/ pink   +
Door Trigger BLACK/ orange   -   20 pin plug at GEM
Notes: This wire controls the door ajar indicator on the dash, must cut the wire and diode isolate it from the instrument cluster. Can also use individual negative door trigger wires in the 26 pin plug at the GEM. They are: yellow/black (LF), gray/red (RF), lt. GREEN/ YELLOW (LR), and pink/lt. blue (RR).
Dome Supervision BLACK/ lt. blue   +   top plug of fuse box
Trunk/Hatch Pin
Notes: On the sedans use BLACK/ pink (-) at the light in the trunk. On the wagons use WHITE/ purple (-) in the 26 pin plug at the GEM.
Hood Pin tan/lt. green   -   26 pin plug at GEM
Trunk/Hatch Release
Notes: With keyless entry it is purple / YELLOW (-) at the switch. Without keyless entry it is gray/red (+) at the switch. On the wagon, to unlock just the rear hatch use yellow/lt. green (-) in the 26 pin plug at the GEM.
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm pink/white   -   26 pin plug at GEM
Disarm No Unlock see factory alarm disarm
Tachometer tan / YELLOW   ac   PCM
Notes: The PCM (Powertrain Control Module) is on the passenger side firewall under the hood.
Wait to start N/A
Brake Wire RED / lt. green   +   brake pedal switch
Parking Brake
Horn Trigger purple or blue   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: SecuriLock Part #: 556S, 556U, or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.car with multiple 12 constant wire -- posted image.
Tuesday, October 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
