2004 pontiac GTO alarm/remote start wiring
Nlzx
Member - Posts: 9
Posted: April 24, 2005 at 12:47 PM / IP Logged
Does anyone have the security/remote start wiring information for a 2004 Pontiac GTO? Also any bypass modules and/or procedures would be apprecaited.
Thanks in Advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 25, 2005 at 12:43 AM / IP Logged
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=5517&product=Remote%20Start
Be careful where you get your constant power for your unit, as you can see the ignition wires (constant 12v) are very weak.....I have NOT done one of these cars yet!
KarTuneMan
Posted: April 25, 2005 at 12:48 AM / IP Logged
http://www.designtech-intl.com/Content/techsupport/wirecolors/VehicleDetail?modelID=1786
Try this one too...
Tuff one, no info from DEI on the ignition override...WoW.   And the whole 12v issue...Jeeze
Good luck
overworked2
Copper - Posts: 132
Posted: April 25, 2005 at 5:48 AM / IP Logged
do a search in Australian sites regarding the Holden Monaro thats where the car was originally built, the wiring system is te same.
Check all advice given with a meter
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
