Sound Deadener
wrathchild281
Copper - Posts: 241
Posted: April 27, 2005 at 4:10 PM / IP Logged
hey you guys im about to install 4 memphis 12in PR subs with a memphis 1000d amp. I think i should get my truck dynamated or something. I have a dodge dakota extended cab and was wondering if i should dynamat the whole truck or not. and about how much would i need to do that. Also what would you guys recommend besides dynamat. thanks
jeffchilcott
Platinum - Posts: 2,483
Posted: April 27, 2005 at 5:23 PM / IP Logged
I would highly highly recommend brown bread, kinda expensive though $2-$5 a running foot (1x3)   I will also recommend using Mar-Hyde Rubberized Undercoating,   I recommend Mar-hyde specifically because it goes on very even and drys quicker then most others.    You can find it at wal-mart.     If you really want to go nutz, do like we are doing right now. undercoat, then brownbread, then undercoat again.     really makes a diffrence in the stability of flimsy metal surfaces,   panels with large opening's behind them ect.    but also adds alot of weight!
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
wrathchild281
Copper - Posts: 241
Posted: April 27, 2005 at 5:34 PM / IP Logged
ok wieght isnt an issue but how much is the undercoating and how much of everything will i need? i want to do the whole truck.
djkeebz
Member - Posts: 13
Posted: April 27, 2005 at 11:09 PM / IP Logged
Mar-hyde is 2-3 dollars a can and easy to use. Just be sure you do it in a ventilated area and the smell will take a few days to go away!
