whats this fuse for
HaMiLTon5
Posted: May 02, 2005 at 10:53 AM / IP Logged
its labeled 'tcb' its a mini 10a fuse in the fuse box under the hood im having problems with my power lock on the driver side unlocking and my car wont stay running because of 'security' i was down messing aorund with my bcm finding my horn wire i got it and taped up and now i have the problems i found that fuse bad and im sure i didnt pull out the 2 wires already down at the bcm I need ideas, thanks.
Jarmizz
Member - Posts: 8
Posted: May 04, 2005 at 2:41 AM / IP Logged
Transmission control block???? So is the fuse blown? do you have a owners manual?? also you could check of theres a voltage across the fuse to see weither or not it is being used etc etc
