F/R Speaker fade
fitsus
Posted: May 04, 2005 at 5:23 AM / IP Logged
I only have a 4 speaker system and after setting it up I went to fade to rear only and the speaker coming off the amp are the same I need to be able to fade front speakers off, can this be done by just switching the radio speaker wires to the other leads on the radio.    thanks
DYohn
Platinum - Posts: 10,741
Posted: May 04, 2005 at 2:04 PM / IP Logged
What's the head unit?  What's the amplifier?  How's the HU sending its signal to the amp?
Captanham
Silver - Posts: 365
Posted: May 04, 2005 at 11:13 PM / IP Logged
do you have a 4 channel amp on all the speakers or just a 2 channel on your rears? your post didn't make much sense at all
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
fitsus
Posted: May 05, 2005 at 6:59 AM / IP Logged
I'm new to this amp thing, it's a 2 channel with the rear speakers connect to the amp the  front to the radio. I switched them out and it fixed the fade problem but now the amp speakers sound muffled and lower volume then with amp off.
fitsus
Posted: May 05, 2005 at 7:59 AM / IP Logged
The HU is a pioneer DEHP 7200 and the amp american pro 400w
Captanham
Silver - Posts: 365
Posted: May 05, 2005 at 12:34 PM / IP Logged
check all your settings, make sure you have it on full and not a LP or something like that, or have it on HP, make sure you have it comming out of the correct set of rca's on your cd player, make sure it's not the non fadeing subwoofer outputs
Bad Boys Customs
DYohn
Posted: May 05, 2005 at 12:46 PM / IP Logged
Also check the electrical phase between the speakers connected to the amp (+ to + and - to -)
