Odometer Resetting
camwise
Posted: May 10, 2005 at 10:18 PM / IP Logged
Hey I have a 1997 Jeep Wrangler and I changed some wiring for a CD player.  Now whenever I turn off the Jeep all Miles I have added onto my jeep gets erased.  When I start my jeep again.  The Odometer resets back to when I changed my wiring.  Help please.  Sorry I couldn't be more descriptive.
Platinum - Posts: 12,488
Posted: May 10, 2005 at 10:33 PM / IP Logged
Try and set everything back to original with the CD wiring and see if the problem is still there. If it is, then try removing the battery terminal ( -) side for about 10 minutes and see if this resets the computer. If this doesn't work, you may have to bring it back into the dealer for a scsan to see if the BCM was damaged in any way from the CD installation... which I doubt, but you never know.
** Don't tell them that you did anything to the CD player and see if they can tell you what is wrong. If you tell them that you removed the CD player then they have something to blame and they will automatically blame the installation, kind of like when a remote starter is installed..... it's an easy out for them. **
Francious70
Silver - Posts: 629
Posted: May 11, 2005 at 11:09 AM / IP Logged
no mileage being added is a bad thing? Odometer Resetting -- posted image.
Paul
vrsc
Member - Posts: 13
Posted: May 11, 2005 at 11:32 AM / IP Logged
Paul
True:D:D:D
kgerry
Platinum - Posts: 3,455
Posted: May 11, 2005 at 12:36 PM / IP Logged
this happened on my BMW once years ago for a different reason and i drove it for about 5 years without it adding a km to the odo..... i would fix the problem just before you are ready to sell the vehicle... ha ha
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Thorin_II
Member - Posts: 24
Posted: May 12, 2005 at 5:55 AM / IP Logged
yeah, just after you've figured out what u did and fix it, u may want to tell others. lol!!
eba eba
Posted: May 15, 2005 at 11:10 AM / IP Logged
Dodge can still get the true reading, i knew a guy that this happened to and when he sold the car there was a bunch of thing worn out and the new owner brought it in to the dealer to get stuff fixed and they got the true millage from another computer on the car (i think tranny)
ss-installer
Silver - Posts: 444
Posted: May 15, 2005 at 7:40 PM / IP Logged
the only wire that even goes to the dash cluster is your dimmer and illumination wires (orange and ORANGE / white). try unhooking those and see what it does. worth a try?
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
