What amp do I need
agne
Member - Posts: 9
Posted: May 11, 2005 at 5:48 AM / IP Logged
I just got my hands on some new rear speakers:
Max power: 190W
Nom power: 90W
Imp: 4
I have no idea what to chheck for when bying my amp. My cdplayer got 4x45w and I doubt that is enough. I thought about buying this amp:
Output: 2 x 60 W vid 2 W, 2 x 35 W vid 4 W
Max output 300 W
Is this enough for my rear speakers?
jdog0411
Copper - Posts: 150
Posted: May 11, 2005 at 2:04 PM / IP Logged
First thing is, throw the max wattage ratings out the window and don't even think about them. They're useless. You didn't provide any specifcs on brand of amp, speakers, etc, and what type of sound you are looking for, but your cd player head unit ratings are probably max ratings. Your unit probably puts out 10-15 watts rms continuously. I'm sure 60 watts rms would be plenty sufficient to power your rears, especially since they really are only for fill anyway.
2004 BMW 325ci.
Alpine CDA-9885
JL 300/4 and 250/1
JL XR 5.25 comps
Infinity Kappa Perfect 12
Francious70
Silver - Posts: 629
Posted: May 11, 2005 at 5:26 PM / IP Logged
Yea, that amp would put out 35 watts at 4 ohms (which I'm assuming is what your speakers are). I'd say you have four options.
1) Since they're only rear fill, you could run them mono, But that'd be 2 ohms bridged on that amp, so throw that option out the window.
2) You could run them in stereo, but each speaker would only get 35 RMS.
3) You could run them off the CD player. If it's an aftermarket player, they'd each get ~20 watts RMS stereo.
This way you could save the money from the amp, and the power differences woudn't be audible.
4) You could wire the speakers in parallel for a 2 ohm load. Most CD players will support a 2 ohm load on the rear channel bridged (at least mine does: Pioneer DEH-P7400MP) With this sption, you'll get ~35 watts RMS to each speaker. And you have extra money from not buying the amp.
I like option #4 the best.
Paul
dwarren
Posted: May 11, 2005 at 5:33 PM / IP Logged
Francious 70 wrote: "4) You could wire the speakers in parallel for a 2 ohm load. Most CD players will support a 2 ohm load on the rear channel bridged (at least mine does: Pioneer DEH-P7400MP) With this sption, you'll get ~35 watts RMS to each speaker. And you have extra money from not buying the amp."
I would disagree and certainly not recommend that idea of running a deck amp at 2 ohms. Internal amps on decks are not stable to 2 ohms unless otherwise stated. You will soon be investing in a new deck.
agne
Member - Posts: 9
Posted: May 12, 2005 at 7:46 AM / IP Logged
I can't give much more info on the speakers I got 'em from a friend that didn't need 'em anymore. He also had a amp for me if I want to buy one cheap. The same story with this one, he did not provide me with any specs. All I know is that its a Jensen Road Gear:
2 x 125WATT
MOSFET:
250 WATT
Basbooster 6dB increase
Channels: 2
Max Watt: 300 W
Input: 1 x RCA
Output: 1 x RCA
Sieze: 55 x 250 x 200 mm
Will this one work with my rear? :)
