sub ring supports
IQinstall
Posted: May 12, 2005 at 8:54 AM / IP Logged
After I have my fg box done, do I leave the dowels in for support? I thought that I would remove them and try to lay a little glass from the inside. Do I need to do that or will the ring stay strong with just the glass over the top. Thanks for any addvice.
astro
Master Asylum
Silver - Posts: 400
Posted: May 12, 2005 at 9:13 AM / IP Logged
Leave the dowels in for support. If I recall correctly, someone wrote a tutorial that tried FGing in the inside and it was a just a pain with the dowels. There really is no structural value to that at all. Just FG the ends of the dowels to the interior on the ring and the base supporting and call that done.
1998 Monte Carlo w/
Eclipse CD8454
2xRockford 5.25" Power 2-way T152C
2xRockford 6"x9" Punch 3-way FRC4369
1xMemphis 16-MCH1300 5-channel
2xKicker 12" L5 Solobaric-2 Ohm
M&mfabrications
Copper - Posts: 95
Posted: May 12, 2005 at 10:47 AM / IP Logged
It depends on how your dowels are in place. If they are screwed in you may be able to leave them. Also make sure thay don't interfere with your speakers fitting in the box. I always remove mine because I use hot glue to hold them in place. I also like to glass around the edges of the rings from inside the box to ensure that they are not going to move.
