2001 camry, keyless/remote start
accord78
Copper - Posts: 97
Posted: May 19, 2005 at 5:46 PM / IP Logged
Hello people need to know where the wire are for this car. insatlling a keyless entry and remote start. and another question about this car do i need to isolate the starter wire on this car beacuse i heard that sometimes this wire has a feed back?
mo12v
Posted: May 19, 2005 at 9:15 PM / IP Logged
Constant 12 voltsWHITE & WHITE/ REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterREDIGNITION SWITCH HARNESS
Dome LightRED / WHITE (-)7 PIN CONNECTOR AT THE FUSE BLOCK
Trunk Pin SwitchRED / YELLOW (-)AT LIGHT IN TRUNK
Parking LampGREEN (+)13 PIN CONNECTOR AT THE FUSE BLOCK
Power LockL GREEN20 PIN WHITE CONNECTOR
Power UnlockD GREENIN DRIVER KICK PANEL *
* Child Safety Lock - BLUE/RED (-) In Same Connector As Door Lock Wires Above.
Child Safety Locks
Accessories
Window UpD\ GREEN P\ GRN/WHT D\ GRN/YEL P\ GRN/BLK @ MAIN SWITCH
Window DownF/ RED F/ RED / BLU R/ RED / YEL R/ RED / BLK
Ign Key WarnBLUE/BLACK (-)IGNITION SWITCH HARNESS 2 PIN CONN.
Trunk ReleaseN/A
OEM HornGREEN/ BLACK (-)STEERING COLUMN HARNESS 6 PIN CONN. *
HeadlightsRED / YELLOW (-)AT HEADLIGHT SWITCH
OEM Alarm ArmBLUE/WHITE (-)20 PIN CONNECTOR IN
OEM Alarm DisarmRED / GREEN (-)DRIVER KICK PANEL
* Horn Wire Can Also Be Found In 12 Pin White Connector On Right Side Of Fuse Box [GREEN/ BLACK (-)]
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLACK/ ORANGEAT ENGINE CONTROL MODULE *
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS (HEAT/AC/ECM)
Ignition #3N/A
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightRED / BLACK (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostYELLOW /GREEN (-)REAR DEFOGGER SWITCH
* Engine Control Module Is Located Behind The Glove Box.
Immobilizer Bypass
MO
firewin
Member - Posts: 6
Posted: May 21, 2005 at 9:51 AM / IP Logged
hi
ive installed alarm with this car, and i would like to change some connections. instead for connecting it to parking lights can i connect the wire to (right and left)signal lights.
can you please give me info where can i locate my signal lights
thanks a lot
KarTuneMan
Platinum - Posts: 7,056
Posted: May 21, 2005 at 11:12 AM / IP Logged
Use the parking light wire....a one wire hook up with NO problems, and accomplishes the same end result.
easy to find as well, green wire at the bottom of the fuse box, UNDER the fuses. POS(+)
