pulse timer relay & info on directfax
mavrick
Member - Posts: 10
Posted: November 18, 2002 at 8:58 PM / IP Logged
I am looking for a directfax document #1091?
For wait to start for a diesel engine (F-350) Where do I find this?
how do I get this diagram?
The second thing is I need to install a pulse timer relay for the wait to start, where can I get one?
I have check Radio shack and about 6 differant electronic store to no avail. help.
Thanks alot for the great info.
Player69
Silver - Posts: 504
Posted: November 18, 2002 at 9:08 PM / IP Logged
what year is the truck and what kind of starter are you intalling? Does it have the choice betweek + or - input for glow plugs?
mavrick
Member - Posts: 10
Posted: November 18, 2002 at 9:11 PM / IP Logged
the truck is a Ford F-350
the remote starter is a Pro start (Auto start unit)
it only has a + input for the glow plug
and I don't have the CD stacker to us the input wire from that either
Player69
Silver - Posts: 504
Posted: November 18, 2002 at 9:30 PM / IP Logged
Again, what year is the truck.  199? 200?
mavrick
Member - Posts: 10
Posted: November 18, 2002 at 9:36 PM / IP Logged
Sorry.... its a 2003 F-350 ford
Player69
Silver - Posts: 504
Posted: November 18, 2002 at 9:45 PM / IP Logged
Well, according to my info that truck does not have a way to get the glow plug wires because it uses a data bus signal to the cluster.
However, I have been able to find a glow plug wire at the back of the instrument cluster.  It is a BLACK/ pink wire.  Test this with a DMM, it should be ground when the glow plug light is on and +12 after that.
If this is the case, you are in luck.  Because your pro start only has a + input you need to use a relay as follows:
85 to BLACK/ pink wire of glow plug
86 to ignition (+12v when ignition is on)
87 to ignition (+12v when ignition is on)
30 to remote start glow plug input
You might have to hook 87a to ground.  Try it without first.
If the BLACK/ pink wire does not exist or does not test right you will have to use a timed start.  I don't think pro start has that option.
mavrick
Member - Posts: 10
Posted: November 18, 2002 at 9:50 PM / IP Logged
Thanks Player69, I hope this will works I will try it tomorrow again thanks for the info I will be back if it dosn't work out tomorrow.
mobileinstallat
Copper - Posts: 92
Posted: November 18, 2002 at 10:11 PM / IP Logged
This is what I have on a 2002!  not a 2003!
just for ref:
GLOW PLUG WIRE:
For Diesel Vehicles,
PURPLE / ORANGE OR WHITE/ LT. GREEN IN 42-PIN CONN. UNDER AIR FILTER BOX
 The Tach Wire Is Green And Can Be Found In A 42-Pin Connector Found Underneath The Air Filter Box. Remove The Air Filter Box To Access Wires.
like I said this is for a 2002! may not apply! If this is not still good info please correct me!
thanks,
Mark
Mark
mavrick
Member - Posts: 10
Posted: November 20, 2002 at 11:43 AM / IP Logged
Hi from Keith,
this is for Mark the last posting, and of others
the 2003 superduty trucks have changed many of the wire color codes and there is no wiring harness under the air box .
The tach wire not Green the tach wire is White with green stripe. ( this info came stright from a Ford dealer,) but even they didn't even no what wire or wire are for the glow plug.
the 12 volt wire at the ignition harness is Yellow X 2 of them no stripe
I still hoping what Player69 stated above will work but I haven't had time to check it out yet I will kepp you posted,
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
