98 Dodge stratus AVIC-N1 installation
tyrone915
Member - Posts: 13
Posted: May 23, 2005 at 2:22 AM / IP Logged
Hi, i have a 1998 Dodge Stratus 2.4L.  I want to install a pioneer AVIC-N1 and i was hoping that if someone could help me out. I need the wiring diagram for its installation onto my car. especially  the vss and reverse signal input. Can someone please provide wire color and location.  Thanks.
tyrone915
Member - Posts: 13
Posted: May 24, 2005 at 12:38 PM / IP Logged
I just wanted to know if the AVIC-n1 would work without the brain and only play DVDs. I saw the head unit only on ebay and i wanted to know if i shoul buy it?
tyrone915
Member - Posts: 13
Posted: May 24, 2005 at 12:43 PM / IP Logged
I have a 1998 dodge stratus sedan 2.4.  I wanted to know what is the reversegear signal input that is mentioned in the AVIC-n1 installation manual,  where is it located, and what color is it?
extreme1
Silver - Posts: 1,070
Posted: May 24, 2005 at 2:46 PM / IP Logged
No, it won't even power up.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
danieljaluise
Copper - Posts: 125
Posted: May 24, 2005 at 3:18 PM / IP Logged
go in the trunk, take out the taillight and find the light bulb that lights up when the car is in reverse. Find the wire on that bulb that shows 12 volts when the bulb is on, and attatch it to that.
nguyenk
Member - Posts: 31
Posted: May 25, 2005 at 8:17 AM / IP Logged
I didn't even wire up the reserve signal. I don't think that it makes that much difference.
danieljaluise
Copper - Posts: 125
Posted: May 25, 2005 at 8:36 AM / IP Logged
It makes a difference if you are using a rear view camera. That is how the screen knows to switch to the camera when backing up. You dont really need it for gps, because the system will eventually correct the posistion of your car if it is wrong. But for how much an N1 costs, why cut corners like that with something so simple?
tyrone915
Member - Posts: 13
Posted: May 25, 2005 at 12:04 PM / IP Logged
Where does the ORANGE / white cable, the one in the power chord connect to. In other words, what is the lighting terminal.
