2002 cavalier aftermarket radio
deadman1228
Posted: May 23, 2005 at 6:19 PM / IP Logged
can anyone help me out withe a wire diagram for the stock radio harness. I cant find a switched power lead.
bumpingjeep
Copper - Posts: 149
Posted: May 23, 2005 at 7:21 PM / IP Logged
you have to run your own on that car...you can go to the ignition wires but the fuse box is the easiest place to go...metra's 70-2003 harnes even comes with a wire that is the right length to run to the fuse box...windshild wiper fuse is the one I usally go for...but any of them with 12V at ignition only will do...
ss-installer
Silver - Posts: 444
Posted: May 23, 2005 at 9:32 PM / IP Logged
whatever you do dont cut the stock harness.
Mayhem_audio
Member - Posts: 17
Posted: May 23, 2005 at 11:09 PM / IP Logged
pac makes a harnes if i am not mistaken has a power lead  and a switched
matt
redpeppers
Silver - Posts: 483
Posted: May 24, 2005 at 12:32 AM / IP Logged
the fuse panel is a band-aid way to run it......this is not something u should practice.....use a DMM to check for a 10 guage pink wire in the drivers kick or at the ingintion harness.....remember to always fuse wire.
Where theres is a wire there's a way.
homer1
Copper - Posts: 62
Posted: May 24, 2005 at 9:03 AM / IP Logged
Use a Class 2 databus harness adapter - that what you're dealing with... A GMCHIME from Soundgate, or a DCGM09 from Scosche for example. You'll get a switched 12v power lead, get the chimes for all the idiot lights(seatbelts, low oil pressure, key left in ign...etc.) & keeping the RAP(retained audio power - keeps radio going for up to 10 minutes after key-off, if you don't open the door.).
Experience gained is directly proportional to the amount of equipment destroyed - break it & learn!
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
