Valet 561t Remote Starter Wiring
noctumluvr
Posted: May 26, 2005 at 12:27 AM / IP Logged
I am installing this brand for the first time and some of the wiring I can't figure out.
There is a harness labled 4-pin satellite harness with the following lables.
Blue = status output
Orange = accessory trigger
Purple = starter trigger
Pink = ignition trigger
This can be seen on the directed web site.
Anyway, there is no mention of these wires in the installation manual and I don't understand what they are for. Thsi is not my first remote start install but this is the first DEI system. I have all the wiring diagrams for my car and the starter.
Thanks for the assistance.
Tom Darling
Platinum - Posts: 12,488
Posted: May 26, 2005 at 12:34 AM / IP Logged
BLUE  wire is for devices that require a (-) trigger only during remote start sequence such as bypass modules, OEM alarm disarms, etc. The other wires are (-) trigger wires for the respective 2nd ACC , IGN or STARTER if required in the installation. This is to drive a relay.
kgerry
Platinum - Posts: 3,455
Posted: May 26, 2005 at 10:21 AM / IP Logged
in most cases you'll never use this harness ( i have over 100 in a shop box here)... you can use the blue/white 2nd status wire that is in the same harness as the brake/ tach/ hood pin.....and since it comes with selectable 2nd Ign/2nd Acc already... it's very rare you ever need to power extra relays
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
