alarm recommendations
us_test
Copper - Posts: 200
Posted: May 31, 2005 at 10:02 PM / IP Logged
What do you recommend.
Thiking about el-1000E any other suggestions for the price ($150 or less).
I've looked at compustar but the lowest I've seen was $220.
I need dual stage shock sensor (pretty standard), I'll add microwave motion sens, remote start
Want 2 aux output (how can I control say 5 items like windows roll up, remote start)
I want 2 sirens + mini piezo "ear bleeders" inside (is this a good idea, how do I wire multiple sirens and piezo)
I'm open for suggestions so tell me what other options are up there.
gcorrea
Silver - Posts: 436
Posted: May 31, 2005 at 11:42 PM / IP Logged
good alarm at a good price look into the k-9 classic(4 button remotes)by omega research. maybe about 65 bucks. i bought mine locally for 54 bucks, just depends where you live i guess. for the sirens use a relay and wire them to the same output.
gcorrea
KarTuneMan
Platinum - Posts: 7,056
Posted: June 01, 2005 at 9:37 AM / IP Logged
Manual trans or NOT....?  If so get the compustar, save your cash and get it...it'll be worth it!
us_test
Copper - Posts: 200
Posted: June 01, 2005 at 11:08 AM / IP Logged
Manual.  How about autopage commando or syntek (which one would be best out of the 3).
Can you program compustar without bitwriter (using the remote)?
OhioMike1101
Silver - Posts: 343
Posted: June 01, 2005 at 7:49 PM / IP Logged
Look at the autopage RS-855LCD for RS/Alarm
RS-520LCD for just an alarm or the rf-610 if not needing 2 way.
They all have 6 channels of outputs.  2 door lock dedicated, 1 trunk, and 3 aux.  All of them except the door locks can be programmed for timed, momentart, and latched which is a really nice feature.
us_test
Copper - Posts: 200
Posted: June 02, 2005 at 7:34 AM / IP Logged
Thans Mike.  I was looking at the 855 and the Audiovox 996a.
The LCd720 autopage is nice also bu only 4 chanells so I guess that woul only leave 2 available (well 1 and the trunk).
520 is definnetley nice. the 520 and 720 have the AM transmitter 855 has FM for better range I assume.
Autopage brochure makes it very easy to see what options each one has.
Any idea on a similar cheaper equivalent of DEI 530T window module (pricey).  I say some for $17 on ebay.
