2001 civic ex
motr
Posted: November 20, 2002 at 7:40 AM / IP Logged
LOOKING FOR SECURITY INFORMATION FOR THESE VEHICLES
Kerrigan's 12v Installs
Platinum - Posts: 12,488
Posted: November 20, 2002 at 8:47 AM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ red           |+  |ignition harness            |
|       POWER LOCK|WHITE/ blue          |-  |gray plug above drivers kick|
|     POWER UNLOCK|WHITE/ green         |-  |gray plug above drivers kick|
|       LOCK MOTOR|yellow/black        |   |back of the fusebox *3      |
|     UNLOCK MOTOR|YELLOW /GREEN        |   |back of the fusebox *3      |
|    DISARM DEFEAT|yellow              |   |back of the fusebox *3      |
| PARKING LIGHTS +|RED / black           |   |back of the fusebox         |
| PARKING LIGHTS -|blue                |   |factory alarm plug *1       |
|       HEADLIGHTS|blue/red            |-  |headlight switch            |
|     DOOR TRIGGER|*2                  |-  |factory alarm plug *1       |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|red                 |-  |factory alarm plug *1       |
|       TACHOMETER|blue                |   |test connector *4           |
|      SPEED SENSE|WHITE/ green         |   |PCM *5                      |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|orange              |-  |steering column             |
|           WIPERS|blue (L), blu/yel(H)|-  |steering column             |
|  LF WINDOW UP/DN|RED / blk - RED / yel   |A  |drivers window switch       |
|  RF WINDOW UP/DN|blu/red - blu/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|brn/wht - brown     |A  |drivers kick panel          |
|  RR WINDOW UP/DN|blu/org - brn/yel   |A  |drivers kick panel          |
|        RADIO 12V|WHITE/ red           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|grn/blk - lt green  |   |radio                       |
|       RF SPEAKER|grn/yel - gry/red   |   |radio                       |
|       LR SPEAKER|blu/wht - blu/blk   |   |radio                       |
|       RR SPEAKER|pink - blu/yel      |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555U.  *1 The factory alarm plug is a green plug above the drivers kick panel.  *2 The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE.  *3 In the top left plug.  *4 It is a 2 pin plug to the passenger side of the battery.  *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
