Remote start 98 Chevy Blazer
SoundAudio
Copper - Posts: 242
Posted: June 01, 2005 at 11:49 PM / IP Logged
Can someone tell me seperate locations for the dome light and door trigger besides the courtesy light?  I have both wired to the same point, with a relay operating the dome light, and the dome light will not shut off.  Also is the parking lights wire brown at the switch?
hawn13
Copper - Posts: 171
Posted: June 02, 2005 at 12:01 AM / IP Logged
it is brown at the switch. if you are trying to do dome light supervision it should work there with both door trigger and dome light wire. double check your relay wiring.it should be wired for - trigger. just a suggestion
Moderator - Posts: 12,488
Posted: June 02, 2005 at 12:19 AM / IP Logged
Dome light uses the door trigger and the door trigger wires you can access at the BCM. The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side.Use tan for the drivers door located in pin B4 of the purple plug, orange for the passenger door located in pin B2 of the purple plug, and dk. blue/white for the rear doors and rear hatch located in pin B11 of the lt. blue plug, must diode isolate these wires.
