Installing Power Mirrors
Gentleman
Copper - Posts: 71
Posted: November 21, 2002 at 6:04 PM / IP Logged
I am installing power mirrors on a vehicle that came with non powered ones, the wiring is no proble but I am trying to find a joystick style switch to control them. The factory switches mounted in the door panel and the non powered door panels ae totally different so mounting factory switches is not an option. can anyone make a switch recommendation
Chris Luongo
Platinum - Posts: 3,746
Posted: November 21, 2002 at 6:19 PM / IP Logged
I would just look for anything that's flat and easily mounted...let's think.  The '87-93 Mustangs had a nicely made switch in the center console.  Many Toyotas use a flat switch mounted to the left of the steering wheel.
Just go to the junkyard and take a look around.  Grab a few different styles, so you'll have some options when you go to do your install.
securinu
Silver - Posts: 772
Posted: December 01, 2002 at 11:21 PM / IP Logged
or maybe get the factory one for the specific vehicle
NyxBass
Silver - Posts: 226
Posted: December 08, 2002 at 8:16 PM / IP Logged
securinu - He said that he COULDN'T use the factory ones, because the door panels are totally different. I like the idea of using one form a junkyard. Might even have a wiring harness attached so soldering/crimping will be easy! Good luck.
/NyxBass
Aznpanther98
Member - Posts: 36
Posted: December 09, 2002 at 2:43 AM / IP Logged
u canprobally mount it any where u wish and best bet is the junkyard since they mightnot even care if u take it out or just for a couple bucks good luck
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
