2001 Caravan A/C wiring diagram
vbratjackson
Posted: June 14, 2005 at 10:44 PM / IP Logged
I am in desperate need of a complete wiring diagram (including A/C wiring) for a 2001 Dodge Grand Caravan.  Can anyone help me?  I have searched the net for 2 hours, with no luck.  Thank you.
Chris
thepencil
Gold - Posts: 1,526
Posted: June 15, 2005 at 8:34 AM / IP Logged
I don't know if this helps, but at least you have something here to work with.
DIRECTWIRE™ WIRING INFORMATION - DODGE / CARAVAN / 2001 / Remote Start
12volts lt. blue/red (10A)   +   ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v.
Starter yellow   +   ignition harness
Second Starter PURPLE / brown   -   ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
Ignition pink/white   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory not required for remote start
Second Accessory N/A
Keysense
Power Lock PURPLE / green   -   conn. 3, pin 21 @ BCM
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Can also use Directed 457C or 456L interface modules.
Power Unlock same wire as power lock
Lock Motor tan/white      conn. 2, pin 10 @ BCM
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motor tan/lt. green      conn. 2, pin 28 @ BCM
Parking Lights+ DO NOT USE
Parking Lights- WHITE/ brown   -   headlight switch
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. The headlights are negative trigger thru a 790 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See DirectFax document 1082 for wiring information.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger     -   conn. 3 @ BCM
Notes: There are separate door triggers for each door, they are all in connector 3 at the BCM. The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each. See DirectFax document 1076 for wiring information.
The BCM is in the drivers kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Dome Supervision use door trigger
Trunk/Hatch Pin PURPLE / orange   -   conn. 3, pin 29 @ BCM
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood Pin PURPLE / lt. blue   -   conn. 3, pin 30 @ BCM
Trunk/Hatch Release PURPLE / tan   -   conn. 2, pin 6 @ BCM
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
Power Sliding Door PURPLE / blue   -   conn. 3, pin 1 @ BCM
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Arm PURPLE / lt. blue   -   conn. 3, pin 14 @ BCM
Notes: Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays.
Factory Alarm Disarm same wire as alarm arm
Disarm No Unlock
Tachometer     ac   ignition coil pack
Notes: On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan or blue/orange.
Wait to start
Brake Wire WHITE/ tan   +   brake pedal switch
Parking Brake
Horn Trigger GREEN/ purple   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 555CW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes: Only vehicles with gray keys have the immobilizer.
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 457CW
Alternate Part1 #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2001 Caravan A/C wiring diagram - Last Post -- posted image.
vbratjackson
Posted: June 15, 2005 at 9:46 AM / IP Logged
Thank you, but this doesn't include the A/C wiring, that is the part I need the most.  Thank you for what you had though!
Chris
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
