hood pin
rock1
Copper - Posts: 120
Posted: June 18, 2005 at 12:09 AM / IP Logged
How can you connect the hood pin switch from the bulldog deluxe 62i? The hood pin does not have a connector on it and the wire that connects to the pin is just a wire with no type of connector its just a bare wire.
Platinum - Posts: 12,488
Posted: June 18, 2005 at 3:11 AM / IP Logged
You have to buy a connector for this. It's a female spade connector if the hood pin switch uses a male end. If it uses a bullet type end use a female bullet connector instead.
