95 nissan maxima system install
xoutlawz00x
Member - Posts: 28
Posted: June 20, 2005 at 1:31 PM / IP Logged
what up i have a 95 max and i want to install a system from my stock headunit. waht harness will i need to acuiure the rca output wires.. and are they called hi lo converters thanks..
SoundAudio
Copper - Posts: 242
Posted: June 20, 2005 at 2:50 PM / IP Logged
You need to get a quality Line Out Converter, (LOC).  I have used PAC in the past until I started dealing  Peripheral products.  Good Luck!
xoutlawz00x
Member - Posts: 28
Posted: June 20, 2005 at 5:59 PM / IP Logged
from where and does that include the remote wire
xoutlawz00x
Member - Posts: 28
Posted: June 23, 2005 at 12:37 PM / IP Logged
guys i check all the diragrams and the colors for a 95 nissan maxima is all off.
i have a 95 nissain maxima with bose... and i need to hook up the  hi low  converter someone please help.. asap
Poormanq45
Silver - Posts: 597
Posted: June 23, 2005 at 2:21 PM / IP Logged
Does each speaker have its own amplifier?
If so then you can put the LOC after the amplifiers then wire RCA cables from there to your amp(s)
ALso, check out NicoCLub
That link is directly to the electronics section on the Nissan/Infiniti Forum. My name is the same there as it is here
xoutlawz00x
Member - Posts: 28
Posted: June 23, 2005 at 4:28 PM / IP Logged
i dont know how do i check
xoutlawz00x
Member - Posts: 28
Posted: June 23, 2005 at 4:50 PM / IP Logged
is that black box behind my stero my amp
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
