Only one speaker working
lanikai
Posted: June 20, 2005 at 6:30 PM / IP Logged
i have a 94 probe installed a deck, there is only one speaker working, and after consulting 2 installers, one replied the harness, the other thought it was the factory amplifier, whatever the case, i need help, and must discover a way to run my factory speakers directly from the new aftermarket deck.(the amp factory amp as already been suposadly bypassed..)
Teamrf
Gold - Posts: 1,031
Posted: June 20, 2005 at 9:43 PM / IP Logged
Well...if the amp is bypassed(didn't know those cars had amps in them) all speakers should be working. if the harness is working you can pull the radio out and use a test generator to verfiy that. Or you can go directly to the speaker and "pop" them to see where your problem is.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
