Auto Start Wiring Diagram
thminh
Posted: November 24, 2002 at 11:27 PM / IP Logged
Need a wiring diagram for a 2002 ACURA 3.2TL (S) to install an auto start.
th
Platinum - Posts: 12,488
Posted: November 25, 2002 at 5:24 AM / IP Logged
thminh here is the 2002 Acura:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|BLACK/ blue          |-  |passenger fuse box *1       |
|     POWER UNLOCK|orange              |-  |passenger fuse box *1       |
|       LOCK MOTOR|WHITE/ red           |   |drivers fuse box *2         |
|     UNLOCK MOTOR|yellow              |   |drivers fuse box *2         |
|    DISARM DEFEAT|lt. GREEN/ red       |   |passenger MUX module *3     |
| PARKING LIGHTS +|RED / black           |   |passenger kick panel        |
| PARKING LIGHTS -|RED / yellow          |   |left of steering column     |
|       HEADLIGHTS|blue/red            |-  |left of steering column     |
|     DOOR TRIGGER|BLACK/ white         |-  |passenger fuse box          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|blue/green          |-  |drivers fuse box            |
|         HOOD PIN|yellow              |-  |passenger fuse box          |
|TRNK/HTCH RELEASE|WHITE/ red           |+  |passenger MUX module *3     |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blue                |-  |drivers door key cylinder   |
|       TACHOMETER|blue                |   |drivers shock tower *4      |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|WHITE/ black         |+  |brake switch                |
|     HORN TRIGGER|lt. GREEN/ blue      |-  |steering column             |
|           WIPERS|blue & blue / YELLOW  |-  |left of steering column     |
|  LF WINDOW UP/DN|RED / yel - RED / blu   |A  |drivers window motor        |
|  RF WINDOW UP/DN|blu/wht - blu/yel   |A  |RF window switch            |
|  LR WINDOW UP/DN|RED / blu - RED / yel   |A  |LR window switch            |
|  RR WINDOW UP/DN|RED / blk - RED / yel   |A  |RR window switch            |
| SUN RF OPN/CLOSE|grn/yel - grn/red   |A  |relays left of fuse box     |
|        RADIO 12V|WHITE/ green         |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|WHITE/ red           |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                       |
Notes:NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. *1 Located in a green 20-pin connector. Use the key switch in the passenger door to test. *2 Located in a green 18-pin connector. *3 The passengers MUX module is located behind the glove box. *4 In a 2-pin connector near the air intake on the drivers side shock tower.
