starting my car with a remote controler..
jorgefdz
Copper - Posts: 99
Posted: May 03, 2002 at 1:34 PM / IP Logged
hi..
Im from Reynosa, Tamaulipas, Mexico and I don´t speak the english very well. I hope that you understand me, thank you.
 I have a sidewinder 6000 ESP and I want to learn about alarms, I would like to know if  I can conect to my alarm the remote starter?,  It is necesary to buy an other module ?  and how can i do it?
My car is a pontiac Grand prix 1994.
thank you .
Congratulations Who make this web site.!!!!
j.f.l.l.
Moderator - Posts: 12,488
Posted: May 03, 2002 at 2:38 PM / IP Logged
The remote starter has to have an auxilary start input wire so it can remote start by another remote device. The only thing is that if your alarm remote control has bad range, then the remote starter will also have bad range ( just a thought ).
Big Dog
Gold - Posts: 1,265
Posted: May 03, 2002 at 2:43 PM / IP Logged
The Sidewinder is a product from Directed Electronics and they also manufacture a remote starter model 551T which will interface nicely with your alarm.
You can use the RED / white channel 2 output to activate your remote start.
If you plan to keep the alarm armed during remote start then:
Remove the yellow wire ignition input on the 12 pin harness from ignition and attach it to the brown accessory wire at the ignition harness to keep the alarm from seeing an ignition at start-up, make sure the yellow on your starter kill relay sees a true ignition though.
You will need to isolate the impact sensor with a relay, the 551T has an output for this.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Big Dog
Gold - Posts: 1,265
Posted: May 03, 2002 at 2:49 PM / IP Logged
Jeff has a point about range.  What I do is that I use the remote starter to control the alarm.
Obviously if the Sidewinder is new, I would take it back and exchange it for a combo.....it'll come to the same price at the end with the advantage of a simpler install and greater range.
jorgefdz
Copper - Posts: 99
Posted: May 04, 2002 at 1:01 AM / IP Logged
Thanks a lot for your time and your advices.
Tahnks jeff and  Big Dog.
j.f.l.l.
Posted: May 04, 2002 at 8:01 AM / IP Logged
Your welcome and good luck.
HotRod53F100
Copper - Posts: 84
Posted: May 12, 2002 at 6:58 PM / IP Logged
Does your '94 Pontiac have a resistor in the key? The little black thing with a metal line in the middle? I have a '98 Pontiac Bonneville that I am trying to put a remote starter in and let me tell you..it's not fun. The resistor in the key is part of the system known as the PassLock system and my car won't remote start unless the key is in the ignition...really what good is that! I have had a real difficult time trying to find an ACCURATE wiring diagram that shows me which wire to cut into. I will have to cut into the right wire and dump the correct resistance value across the right wires to get it to start. I really don't want to eliminate the Passlock system for security reasons. If I wanted to just ditch the Passlock, it wouldn't bee so bad. I have installed a couple of remote starters in a few different models of GM cars but this one has been a pain!
HotRod
jorgefdz
Copper - Posts: 99
Posted: May 13, 2002 at 12:34 AM / IP Logged
yes hotrod my key have this resistor.
 Really it is my first time, and i want to put it to my alarm. if you want some advices to me, please  post it to me.  thanks .
j.f.l.l.
Posted: May 13, 2002 at 5:29 AM / IP Logged
The 1994 Grand Prix has a VATS system in it and it's a basic bypass that you will need.
This system uses a resistor in the key, use a digital volt meter set to ohms and put 1 lead on each side of the vats chip in the center of the key, find a resistor to match your reading.
Locate the Orange or Black tube running down the steering column from the ignition switch. Cut open the tube to epose the passkey wires insie. Your resistor or trumpet should be within +/- 10 ohms of the key. Either of the passkey wires can be cut. GM uses only a fixed number of different resistors with their PASSKEY/VATS system, your measurement should correspond to one of the following values.
390 Ohms1470 Ohms4750 Ohms
520 Ohms1800 Ohms6040 Ohms
680 Ohms2370 Ohms7500 Ohms
885 Ohms3010 Ohms9530 Ohms
1130 Ohms3740 Ohms11800 Ohms
jorgefdz
Copper - Posts: 99
Posted: May 13, 2002 at 1:22 PM / IP Logged
thanks a lot jeff
j.f.l.l.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
