Switch for clutch
zfshrmn
Member - Posts: 15
Posted: November 24, 2002 at 8:30 AM / IP Logged
can somebody tell me how do I put a switch in the clutch in order for to use the remote start in my truck(ford ranger 2000 5speed 4x4)
thank you.
Player69
Silver - Posts: 504
Posted: November 24, 2002 at 10:26 AM / IP Logged
There already is a clutch switch.  First you need to use a remote start designed for standard transmissions.  Then you need to test the wires at the clutch switch.  There should be a switch that has 2 wires, one will test +12v when you turn the key to start, the other will test +12v when you turn the key to start and press the clutch to the floor.  That last wire is the one you need to hook the starter output of your remote start to!
Player69
Silver - Posts: 504
Posted: November 24, 2002 at 10:30 AM / IP Logged
The wire you are looking for is most likely pink.
Platinum - Posts: 12,488
Posted: November 24, 2002 at 10:46 AM / IP Logged
The Ford F-150's have a BLUE/ORANGE wire that is a type 1 clutch . This requires a (+) pulse to engage the clutch. The clutch wire may be the same for the Ranger, but test to be sure.
Player69
Silver - Posts: 504
Posted: November 24, 2002 at 10:51 AM / IP Logged
My info says pink specifically for the ranger.  It is very rarily wrong. Switch for clutch -- posted image.
Jeff, how did you make out with that cover problem?
zfshrmn
Member - Posts: 15
Posted: November 24, 2002 at 11:52 AM / IP Logged
man thank you for you time here is the Alarm I have http://www.slickcar.com/manuals/fmcombo.pdf
when you said to that the last wire is the one you need to hook the starter output of your remote start to
please check my Alarm and let me know witch one is the one that I have to hook it up to.
thank you
Posted: November 24, 2002 at 12:01 PM / IP Logged
Use the violet wire to bypass the clutch. This will give the clutch wire a 12 volt only when starting.
Player69: Still haven't figured out a way to do the pause on the roof switch . Tonneau is easy because there's no pause, but roof is the pain.
zfshrmn
Member - Posts: 15
Posted: November 24, 2002 at 12:04 PM / IP Logged
so all I have to is put a wire from the violet to the wire on thi clutch?
