95 galant Door lock
Cmiller
Posted: November 24, 2002 at 7:15 PM / IP Logged
I'm installing a viper car alarm/keyless entry/remote starter system in a 95 galant.  I'm trying to hook up the negative triggers to the driver side door lock actuator.  do i have to use relays set-up in the actuator/reverse polarity set-up.  Any help would be very helpful as this intergated lock curcuit in the car is baffiling me.  I was hoping to use the lock switch, but it is built right into the cuircut board.
Chris Miller
securinu
Silver - Posts: 772
Posted: November 24, 2002 at 7:43 PM / IP Logged
lock= green / white  ( - )
unlock= red /  green ( - )
both in driver kick panel area
Cmiller
Posted: November 24, 2002 at 7:55 PM / IP Logged
I'll look for those tomorrow, thanks.  I was also wondering where I could find the door pin common wire/ dome light trigger in the galant.
Chris Miller
Cmiller
Posted: November 24, 2002 at 7:58 PM / IP Logged
Alos, I was going to set in tachless and wrap a wire around a spark plug wire since itis a coiless engine, unless someone knows what wire I can tap into to set it to tach mode
Chris Miller
securinu
Silver - Posts: 772
Posted: November 24, 2002 at 8:52 PM / IP Logged
for tach just go to any odd color at the injectors. and for doorpin green / orange in driver kick panel area and is  ( - )
Cmiller
Posted: November 24, 2002 at 8:59 PM / IP Logged
thanks alot for the help, but what do you mean by "odd color"
Chris Miller
Platinum - Posts: 12,488
Posted: November 24, 2002 at 9:17 PM / IP Logged
" ODD COLOR " means taht there are 4 common colored wires for the injectors and then 4 uncommon colors..... use any one of the 4 uncommon clored ones for the tach signal.
