94 Jeep Cherokee Remote Start Wiring
83Rangerman
Posted: June 27, 2005 at 12:04 AM / IP Logged
I'm looking for remote start wiring for a 1994 Jeep Cherokee 4.0L. I'm also wondering if there's a factory security system that needs to be bypassed to allow the vehicle to start.
thepencil
Gold - Posts: 1,526
Posted: June 27, 2005 at 8:53 AM / IP Logged
Yes you do.
Factory Alarm Disarm GREEN/ orange    -   drivers kick panel
DIRECTWIRE™ WIRING INFORMATION - JEEP / CHEROKEE / 1994 / Remote Start
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition blue    +   ignition harness
Second Ignition
Third Ignition
Accessory purple    +   ignition harness
Second Accessory
Keysense
Power Lock ORANGE / purple    +   drivers kick panel
Power Unlock pink/purple    +   same
Lock Motor
Unlock Motor
Parking Lights+ blue/red      drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow    -   underdash light
Dome Supervision
Trunk/Hatch Pin common with doors
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Disarm No Unlock
Tachometer gray/blue   AC   PCM
Notes: Powertrain control module located on left inner fender behind headlight.
Wait to start
Brake Wire white    +   brake pedal switch
Parking Brake
Horn Trigger black    -   ribbon cable st. col.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.94 Jeep Cherokee Remote Start Wiring -- posted image.
