94 Geo Prizm / Corolla 12 volt Harness?
wolf08
Posted: June 27, 2005 at 1:11 PM / IP Logged
I bought a Floor Mat for my Prizm, it said that I had to "hardwire" it. I'm not sure if Corollas use the same exact wires as prizms, should be close though.
I removed the panel under the steering wheel and found the Harness.
I need to know:
1 Which colors are the +12 and the negative? (i dont want the constant 12 volt)
2 Can I open the Harness to make it easyer to connect the wires?
3 Do I need to solder it?
dare_ds69
Silver - Posts: 419
Posted: June 27, 2005 at 6:29 PM / IP Logged
Ignition BLACK / YELLOW   +  ignition harness
for ground use chassis ground.
how own your mind, control your life.
MECP certified. always use a DMM
wolf08
Posted: June 27, 2005 at 6:38 PM / IP Logged
thanks a lot for a fast response!
I dont remember if i have a Black with Yellow wire, I know I have Black though.
And thanks for telling to hook up negative to ground, 'cuase when I did the CD player i there was a ground wire in the harness.
94 Geo Prizm / Corolla 12 volt Harness? -- posted image. i like this website, will come back if i want to hook up the radar detector or alarm system, or more LED's 94 Geo Prizm / Corolla 12 volt Harness? -- posted image.
