old dei 551t
cuffman4wife
Posted: June 28, 2005 at 11:39 AM / IP Logged
I have an old dei 551t remote start that I am going to install to my old dei ultra 900, I already have the ultra 900 installed but I cannot find the correct wiring diagram for my 551t it has a 12pin harness, a ribbon harness leading to a 4 relay, relay bank, and 4 dip switches inside the brain. I used to install at CC for about 4 years in the mid 90's and have not hooked up one of these in so long I cannot remember some of my wires, if I just knew the function of each wire I know that I can install it.  I have an installation manual for the new version 551t but it does me no good because they are totally different. If anyone could help me it would be greatly appreciated.
thanks cuffman4wife
Big Country
moshpitmickey
Member - Posts: 43
Posted: June 28, 2005 at 7:45 PM / IP Logged
I have a manual for the first generation 551t from 1989. What wires do you need?
moshpitmickey
CutDog504
Silver - Posts: 643
Posted: June 29, 2005 at 11:10 PM / IP Logged
I need the same wiring info for an old 551t I have laying around. The date code says its from 1995. I know what all the wires on the relays go to, but I'm not sure about all the smaller wires, also there are several of the same color wires, I think 2 gray, 2 brown, etc.
rsharpe03
Posted: October 07, 2005 at 12:16 PM / IP Logged
Does anyone still have the wiring diagram for the first generation 551t valet remote start, I just need the color codes for the 12 pin harness and the 4 dip switch settings, I can figure out the rest. Thanks Randall
