64 Impala Kick panels
realitycheck
Silver - Posts: 751
Posted: September 07, 2005 at 7:33 AM / IP Logged
I think if you do either one of those sessland your not going to be able to reach your high beam switch.
Sessland
Copper - Posts: 58
Posted: September 07, 2005 at 7:15 PM / IP Logged
I am planning on relocating it. Obviously it won't work the way it is.
dashrat77
Member - Posts: 25
Posted: September 08, 2005 at 7:09 PM / IP Logged
I did pods in a 64 a while back, I just moved the HL switch out of the way, but did nothing to the park brake. Heres pics of the car. Sorry, seems I didnt do pics of the dvr side kick.
http://www.dashratkustoms.com/DBimpala.htm
Sessland
Copper - Posts: 58
Posted: September 08, 2005 at 7:51 PM / IP Logged
This is EXACTLY what I was hoping to find.
Awesome. It's even the same color scheme that I'm using.
Thank a mil, this gives me a great idea.
BTW, How did it sound with the speakers in that location?
AZ-ss
Member - Posts: 31
Posted: September 19, 2005 at 5:37 PM / IP Logged
Dashrat- NICE!
Sessland- You could always do the same design that Dashrat executed. But if you aren't going to use the vents that are located in the kicks, why dont you recess a portion of the kickpanel in that area so your kickpanels dont eat up too much of your floorspace.
I had done a set of panels for an early 60's chevrolet truck that had to accomodate some 6x9's. I first made a fiberglass mounting box molded to the "pocket" where the vents are located, part of the outside mounting lip also served as the base where the speaker mounting baffle was going to be aimed and anchored. I then made stretched material from the aimed mounting baffle to the mounting box to give the exterior a smooth fluid appearance.
Or another option is to replace the high beam floor switch with a relay and a small switch located elsewhere to control the highbeams. ( had to do this for a 84 Bronco that I did kicks for)
Good Luck!
Sessland
Copper - Posts: 58
Posted: September 20, 2005 at 7:52 PM / IP Logged
just curious...
where did you aim the speakers and how did it sound?
