excelon kdc-x917 problem
nathan_454
Member - Posts: 16
Posted: July 05, 2005 at 6:35 AM / IP Logged
I have an excelon kdc-x917 deck in my car. I got it new and it has worked flawlessly up until a few weeks ago. one day I got in my car and it wont power on... It has power to it though, becuase when i turn teh car to teh ON or ACC position, the face moves out to the angled position and stays there. then when i turn the car off. it goes back flat. it doesnt flip around like it is supposed to, but just goes flat in the normal ON position... ITs been really hot here in arizona. could it have just cooked? i hate to see this deck go because its been great up until this happened? thanx ahead guys!
MY System, Pioneer Owns...Thanx Gabe
HU: DEH-P770MP
Fronts: TS-C160R
Rears :TS-A6995
Subs: 2x TS-W106C
Sub Amp: GM-7150M
4 CH: GM-6150F
modena0
Copper - Posts: 85
Posted: July 05, 2005 at 9:51 AM / IP Logged
just a hunch, but check both power connections. maybe the continuous lead has a blown fuse? i'd check both power lines with a multimeter or test light. i know my clarion would act a little funny when the power lines were a little off.
nathan_454
Member - Posts: 16
Posted: July 05, 2005 at 10:29 AM / IP Logged
OK i will try that. I just pulled out my DVOM so ill go check here in a few... thanks for the tip
HU: DEH-P770MP
Fronts: TS-C160R
Rears :TS-A6995
Subs: 2x TS-W106C
Sub Amp: GM-7150M
4 CH: GM-6150F
nathan_454
Member - Posts: 16
Posted: July 05, 2005 at 11:05 AM / IP Logged
just check it out. solid 12 volts at teh deck on both on and ACC. i dunno I took the deck out, might tear into and see if anythings wrong.. doesnt have any smell of burning electrical to it... I dunno..
HU: DEH-P770MP
Fronts: TS-C160R
Rears :TS-A6995
Subs: 2x TS-W106C
Sub Amp: GM-7150M
4 CH: GM-6150F
Hornshockey
Silver - Posts: 520
Posted: July 05, 2005 at 1:27 PM / IP Logged
A Kenwood MASK unit with a problem on the display?  Unheard of!  J/k though really there's a flexible cable that carries the info from the unit to the faceplate while still allowing it to rotate.  I've made plenty of money replacing these.  The part is approx. $12 but you will generally get charged $80-100 for labor.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
nathan_454
Member - Posts: 16
Posted: July 05, 2005 at 2:36 PM / IP Logged
its not just the display, it wont power on at all. or play,,, wont do anytrhing... the face just moves a bit
HU: DEH-P770MP
Fronts: TS-C160R
Rears :TS-A6995
Subs: 2x TS-W106C
Sub Amp: GM-7150M
4 CH: GM-6150F
Hornshockey
Silver - Posts: 520
Posted: July 05, 2005 at 3:42 PM / IP Logged
so when you power it up, the face moves down flat like it does to let you detach the faceplate?
nathan_454
Member - Posts: 16
Posted: July 05, 2005 at 9:26 PM / IP Logged
yeah you got it.
HU: DEH-P770MP
Fronts: TS-C160R
Rears :TS-A6995
Subs: 2x TS-W106C
Sub Amp: GM-7150M
4 CH: GM-6150F
Hornshockey
Silver - Posts: 520
Posted: July 06, 2005 at 3:21 AM / IP Logged
yep; you need yourself a new flexible ribbon cable; MASK units are notorious for this.
SoundAudio
Copper - Posts: 242
Posted: July 06, 2005 at 9:49 AM / IP Logged
Yup I have a 717 and I had it replaced last fall.  It cost me $63 to get it repaired but that is in Kansas.
