Alarm
alucard
Posted: November 25, 2002 at 7:28 PM / IP Logged
does anyone out there have an alarm system wiring diagram for a 2002 DODGE STRATUS R/T COUPE - 3.0l engine?
i want to install a variety of sensors and need the diagram to locate the correct alarm inputs/outputs.
one of the main sensors i am installing is a capacitance proximity switch/sensor (touch sensor). a soon as anyone or anything touches the car, the alarm will sound.
I also intend to install a radar sensor, motion sensor, glass break sensor, mat sensor under the rug, and some other fun things i found.
thanks
alucard
securinu
Silver - Posts: 772
Posted: November 26, 2002 at 5:57 PM / IP Logged
Car Wire Profile for 2002 Dodge Stratus
 Wire ColorLocationInstructions
StarterBLK/RD.IGNITION HARNESS.P.
Notes:
Note: This vehicle is equipped with an immobilizer and must be bypassed when doing remote start. 1. Located in a balck 32 pin plug. 2. These are the door key cylinder wires. Meter the wires while turning the key in the drivers door. Unlock requires a double pulse. On vehicles without factory alarm use purple for lock and Lt GRN/RD for unlock, these are the door lock switch wires. 3. In the plug on the upper right side of fuse box under the driver side dash. 4. Go to the test connector inside the fusebox under the hood, it is a T-shaped plug. Tach is the termianl on the top left of the T, the wire under the terminal is WHT or WHT/RD. 6. To disarm without unlocking, use a single pulse on the unlock wire. 7. Located in a white 43 pin plus. 8 Located in a black 19 pin plug on the back of the fuse box under the drivers dash.
T-Harness Info
Starter Disable/Power: .
Door Lock: ..
Complete Alarm Harness: .
Remote Start: .
Factory Keyless Upgrade: .
Technical Bulletins Related to this vehicle:
Constant 12VWHT/RD.IGNITION HARNESS.P.
Switched 12VDk.GRN.IGNITON HARNESS.P.
Dome LightGRN/YL.FUSE BOX.N/8.
Parking LightsGRN/WHT OR PNK/BLK.LOW IN DRIVERS KICK.P.
HornLt GRN/BLK.STEERING COLUMN.N.
Door LockLt GRN/BLK.DRIVER KICK PANEL.N/1/2.
Door UnlockOR.DRIVER KICK PANEL.N/1/2.
Power TrunkGRN/WHT.DRIVER KICK PANEL.5WI/7.
Left Front Window...
Right Front Window...
Keyless Module...
Tachometer..4.
Trigger LockLt GRN.DRIVER KICK PANEL.1.
Trigger UnlockDk. GRN/RD.DRIVER KICK PANEL.1.
Unlock MonitorBLU/BLK.DRIVER KICK PANEL.1.
Unlock Monitor (Factory Alarm)DISARMS WITH UNLOCK...
Other:ACC BLU/RD IGN HARN
2ND ACC BLU/BLK IGN HA
Thursday, January 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
