Rollup Windows using a motion sensor
delSolvortech
Posted: July 07, 2005 at 8:44 PM / IP Logged
Sorry if this is a repost....
Rollup windows when sector violated
Unfortunatly the diagram link doesn't work....
Roll up on alarm
I am interested in using my DEI 520T motion sensor to roll up my windows when someone gets close to the car. My alarm is a DEI 791XV and I am using a DEI 530T. Any help is greatly appreciated.
Along with that I still would like to use the "roll up when armed " feature.
Powermyster
Silver - Posts: 962
Posted: July 08, 2005 at 3:58 AM / IP Logged
you might need a relay it can be done  i'm sure the motion sensors are neg triggers. but the window module might need a couple of hundred mA to activate.
here is how you would do it.
86 -  12V
85  -  exterior trigger
30  - solid chassis ground
87 to window activation.
this should do the job.
you can try the exterior trigger to the window activation direct. i'm not sure weather it will work or not
Powermyster
Silver - Posts: 962
Posted: July 08, 2005 at 4:05 AM / IP Logged
i was just reading the post there where the guy broke the connection on the ground when armed output. to activate the window module.
for that you could
30  - ground when armed to window mod
87a - ground when armed to alarm
85 -  (-) exterior xone trigger
86  - 12V
this should do the same i thought  without the need for resistors and capacitors. or maybe the connection needs to be severed for longer i'm not sure. probably depends on the window module
alpine0000
Copper - Posts: 160
Posted: July 08, 2005 at 6:14 AM / IP Logged
Roll up on alarm
haha, thats an awesome idea. i didnt think about that one!
Powermyster
Silver - Posts: 962
Posted: July 08, 2005 at 6:34 AM / IP Logged
me neither
no end to the possibilities LOL
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
