Type F locking
Powermyster
Silver - Posts: 962
Posted: July 12, 2005 at 6:13 AM / IP Logged
Ok i have an install coming up first time i tryed this.
and i just don't get it i was looking at the DEI manual. on door locking systems.
i get the principle on which it works.
what i don't get is the realy part they have it set up so whel you unlock the connection  is severed and the doors unlock. this i get.
here is my problem.  most alarms send a pulse right. so as soon as the pulse is over it will remake the connection and dors will lock... atleast this is the way that i see it.  obviously it works can somebody tell me what i'm missing about this system.
I just want to better understand it thats all.
Powermyster
Silver - Posts: 962
Posted: July 12, 2005 at 6:14 AM / IP Logged
or is it a case that when the doors are unlocked and the connection is remade. that the doors won't lock   its will need an earth then to lock it again.
Platinum - Posts: 12,488
Posted: July 12, 2005 at 7:40 AM / IP Logged
Only when the wire is N/O does the locks engage. So when the pulse that is generated is gone, the system doesn't re-lock. the only time it relocks is when the wire is opened again. You have it backwards in your description. Most systems use the ground as a unlock.
Powermyster
Silver - Posts: 962
Posted: July 12, 2005 at 9:01 AM / IP Logged
sorry was just going off memory there..
anyways just thought that i would ask
cheers.
also on this site it showes a diagram with two relays but in the DEI manula it shows only 1.
i didn't look i very close detail but i presume both are acheiving the  same objective
Posted: July 12, 2005 at 11:54 AM / IP Logged
I only use 1 as well for the Type F system.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
