1998 cadillac eldorado
mxxmikexx
Silver - Posts: 796
Posted: November 26, 2002 at 7:51 PM / IP Logged
are there any other locations other than behind the rear seat to grab the trunk release wire, and the parking light wire?, working on car tomorrow, trying to get some info before then, thanks !
djfearny2
Silver - Posts: 810
Posted: November 26, 2002 at 8:13 PM / IP Logged
what sucks about the caddies is that everything is in the trunk or basically what you have to do is take out the back seet and you will see all the wires needed test everything and shoot you may be able to do an alarm in that area. all you need to do is run the wires needed to connect to such as the followings.
acc, igintion one , ignition two. , start, constant., tach (ran to engine) and hood pin (ran to engine , i think you can even get door locks in the back i am not sure but i belive so.
Jon
Installer/Help Technician
---coral springs florida---
securinu
Silver - Posts: 772
Posted: November 26, 2002 at 10:44 PM / IP Logged
trunk release is black ( - ) as switch in dash
park lights   is brown ( + ) in driver kick panel
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
