how do i change a + alarm output
kevinh30
Member - Posts: 14
Posted: November 26, 2002 at 8:39 PM / IP Logged
How do I change a +alarm output to a - output?  Can I just use a relay?  Thank You
kjh
matrix
Member - Posts: 26
Posted: November 26, 2002 at 9:37 PM / IP Logged
Hopefully you know how to use a relay, brcause that will make this much easier. If not, just let me know. Just put the positive from the alarm to eitheir 85 or 86. It usually doesn't matter(if it does connect to86). Ground the other side(the one not used above). Then ground 30. Lastly put the output (wire to wherever you want to give a negative signal to) to 87. That should take care of your problem.
matrixman
kevinh30
Member - Posts: 14
Posted: November 26, 2002 at 9:41 PM / IP Logged
I really appreciate it matrix
kjh
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
