wiring diagram for a 96 galant
zmsaad
Member - Posts: 34
Posted: November 27, 2002 at 8:40 AM / IP Logged
I am planning to install a remote start/keyless entry system RS900ER. Any body could tell me where can I find the wiring diagram and any helpfull hints will be appreciaed. Do you realy need to hook the TACK wire or not. thanks
cpgoose
Gold - Posts: 1,098
Posted: November 27, 2002 at 10:13 AM / IP Logged
Here's the link for the wiring you'll need:  1995-96 Mitsubishi Galant Alarm Information
Yes, I recommend using the tach wire.  I'm not sure about your car, but sometimes you can find it under the dash, rather than going through the firewall to the distributor.  Just makes things easier in my opinionwiring diagram for a 96 galant -- posted image..  I installed 2 remote starters with using the tach wire, and I wound up going back in, and hooking up the tach wire.
zmsaad
Member - Posts: 34
Posted: November 27, 2002 at 11:03 AM / IP Logged
thank you cpgoose, i will try to find the tach wire and hook it thanks again
cpgoose
Gold - Posts: 1,098
Posted: November 27, 2002 at 11:04 AM / IP Logged
no problemo.
zmsaad
Member - Posts: 34
Posted: November 30, 2002 at 12:16 PM / IP Logged
hi guys, ineed some heli here. I installed the starter/ keyless system, but I can not get the horn to work. The horn does not work when the ignition key is at the off. I connected the wires as indicated in the charts, which is the L. Green at steering column to the system wire, it did not work. Do I need a relay on this car. Thanks
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
