04 silverado amp wiring route
silverado_lr4
Posted: July 23, 2005 at 1:07 PM / IP Logged
Hi, there I'm new  to the  forum, and  I just  purchased an 04 Silverado and  I'm wanting  to run a  power  wire  for  an amplifier, just  needing  help in routing  it, Does anyone  know of a good  spot  in the  fire wall where  thers a grommet  or will I have  to drill a hole for the power wire. Any help is really  appreciated.
Thanks,
Jose
Platinum - Posts: 12,488
Posted: July 23, 2005 at 1:13 PM / IP Logged
What gauge wire are you trung to run ?
silverado_lr4
Posted: July 24, 2005 at 10:11 AM / IP Logged
i believe is 8 awg.......thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: July 24, 2005 at 11:35 AM / IP Logged
look on the outside (underhood) of the firewall....theres a spot where ther clutch would go thru if it were a manual trans ....thats the spot to drill your hole. With 8g wirw you might slip it thru a large factory rubber grommet....be careful you dont damage any wires allready in the grommet.  Make sure your cable is REAL CLEAR of the ebrake, and the mechanism. That thing willl shred a power wire
silverado_lr4
Posted: July 24, 2005 at 12:03 PM / IP Logged
Thanks for the info!.... I'll try it later..its raining..lol.
TruckSystem
Copper - Posts: 185
Posted: July 25, 2005 at 9:39 AM / IP Logged
I put a 4 gauge wire through that factory grommet with no problems, 8 guage will go through there.
2003 Chevrolet Silverado Standard Cab ~ Alpine CDA-9851
Diamond Audio D3600.1 ~ 2x Diamond Audio TM310D4
Diamond Audio D3400.4 ~ Diamond Audio Hex S600s
AstroStart RS5204 Remote Start/Alarm
