Re: viper 791XV 1997 Cavalier
rabbit713
Member - Posts: 6
Posted: July 30, 2005 at 9:31 PM / IP Logged
I was just wondering if anyone can help me out there, I want to install this alarm in my car but I need wiring diagram, and to be more helpful a person who has the exact same alarm installed in their car
Rabbit713
swamprat323
Gold - Posts: 1,335
Posted: July 30, 2005 at 9:42 PM / IP Logged
1997 CHEVROLET CAVALIER 4DR SEDAN
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED (2)          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Starter 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          LIGHT GREEN/ BLACK DR
               YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS. *SEE DOCUMENTS
     LF Latch          LIGHT GREEN/ BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE DASH
     RF Latch          LIGHT BLUE          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE DASH
     Trunk Trigger          BLACK          (-)          LIGHT IN TRUNK
     Parking Lights          BROWN          (+)          AT HEADLIGHT SWITCH
     Convenience
     Headlights-Lo          DARK BLUE          (-)          PNK (-) AT HEADLIGHT SWITCH
     Headlights-Hi          PINK          (+)          AT VEHICLE LIGHT SWITCH
     LF Pk Lt Bulb          BROWN          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          BROWN          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          BROWN          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          BROWN          (+)          AT REAR RIGHT PARKING LIGHT
     Trnk Release          BLACK/ WHITE          (+)          AT OEM KEYLESS MODULE DR.SIDE OF TRUNK
     Remote Start
     Ignition 2          BROWN          (+)          IGNITION SWITCH HARNESS
     Ignition 3          WHITE          (+)          IGNITION SWITCH HARNESS PCM+CLUSTER
     Accessory 1          ORANGE          (+)          IGNITION SWITCH HARNESS (HEAT/A.C.)
     Anti-Theft Type          RESISTOR BASED SYS
     Anti-Theft Descript          PASSLOCK
     Key Sense          LIGHT GREEN          (-)          IGNITION SWITCH HARNESS
     Tachometer          WHITE          (-)          2.4L+2.2L AT PCM PASS FRNT FDR SEE NOT
     Speed Sense          GREEN / WHITE          (AC)          PCM,UNDER PASS FENDER,BLK PLUG,PIN 16
     Brake Lights          WHITE          (+)          AT BRAKE SWITCH
     Reverse Lights          LIGHT GREEN          (+)          AT SWITCH ON TRANSAXLE
     Horn          BLACK          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          BLACK          (+)          POSITIVE TRIGGER
               LOCK WIRES WILL BE (+) IF THE VEHICLE IS EQUIPPED WITH OEM KEYLESS ENTRY.
     PowerLock          LIGHT BLUE          (+)          DRIVER'S KICK PANEL AT DOOR HARNESS
     LF Window Up          DARK BLUE          (REV)          MASTER WINDOW SWITCH IN DRIVERS DOOR
     LF Window Dn          BROWN          (REV)          MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Up          LIGHT BLUE          (REV)          DRIVERS KICK PANEL HARNESS FROM DOOR
     RF Window Dn          TAN          (REV)          DRIVERS KICK PANEL HARNESS FROM DOOR
     LR Window Up          DARK GREEN          (REV)          DRIVERS KICK PANEL HARNESS FROM DOOR
     LR Window Dn          VIOLET          (REV)          DRIVERS KICK PANEL HARNESS FROM DOOR
     RR Window Up          LT.GREEN          (REV)          DRIVERS KICK PANEL HARNESS FROM DOOR
     RR Window Dn          VIOLET          (REV)          DRIVERS KICK PANEL HARNESS FROM DOOR
swamprat323
Gold - Posts: 1,335
Posted: July 30, 2005 at 9:43 PM / IP Logged
1997 CHEVROLET CAVALIER 2DR COUPE
     Security
     Convenience
     Remote Start
     Modules
     WIRE          LOCATION
     Doorlocks/Windows
Sunday, October 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
