2000 integra remote start problems
spider228
Member - Posts: 8
Posted: August 03, 2005 at 3:45 PM / IP Logged
Ive recently installed a Viper 550esp w/remote start in my 2000 integra.  The alarm part works fine but the remote start is being a pain in the azz.  When i push the remote start button the starter ingages for about 1sec instead of 6sec like its supposed to, but when i turn the key to the once to the ON possition and push the button then the car will start.  I did the history diagnostics and it said (over rev) i dont understand.  The radio has an anit-theft light that blinks, does that have somthing to do with it.  There is also a black box with a green button that is mounted behind the panel under the the sterring wheel. Wut is that? Does that have somthing to do with the factory alarm or wut?
Platinum - Posts: 12,488
Posted: August 03, 2005 at 11:01 PM / IP Logged
You need the PKH2 or a universal bypass module for the 2000+ Integra otherwise the car will not start without a programmed key present.
spider228
Member - Posts: 8
Posted: August 04, 2005 at 2:36 PM / IP Logged
What is a PKH2 and where can i get one.
mo12v
Posted: August 04, 2005 at 2:51 PM / IP Logged
The IB-PKH2 ( No Key Required ) is made by OMEGA, also patent rights go to a couple of other companies who sell same.
U can also use a KEY with PASS-4 by OMEGA
MO
Posted: August 04, 2005 at 3:33 PM / IP Logged
PKH2 is a keyless bypass module that you need to interface with the OEM Immobilizer system in order to bypass the chipped key system in the Integra. Without a bypass module, you will not get the vehicle to start without properly bypassing the need to have a key in the ignition. The PKH2 uses the Immobilizer wires to copy a code from the master key and upon remote starting it will send this code to the Immobilizer and release the fuel management system to allow the car to run after starting. We sell the PKH2 system & if you want to purcahse one you can email or PM me.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
