meter for setting gains
hvaughn
Member - Posts: 34
Posted: August 03, 2005 at 5:27 PM / IP Logged
I read a few posts about how to properly set the gains on an amp using a meter. Question.... What kind of meter to I need to get to do this, and where can I get one? Also,
is this worth buying and doing or am I wasting my time and money.
Thanks in advance,
Heath
jugga-nemo
Copper - Posts: 81
Posted: August 03, 2005 at 6:04 PM / IP Logged
You would want to purchase a mulit-meter from any local hardware store. I feel that one is extremely important to own especially since I work on the car electronically and mechanically. They not very expensive (mine was like $50 for a decent digital one). To obtain the AC volts that your amp should play at, follow this formula: E=SQR(P*R) where E=volts, SQR=Square root, P=Power in Watts, and R=Resistance in Ohms. When you test a channel, disconnect all speakers from the amp, and then test. Just make sure that your HU settings are at the highest you will adjust them to (volume, eq, etc.)
stevdart
Platinum - Posts: 5,816
Posted: August 04, 2005 at 12:33 AM / IP Logged
You can't go through life without a multimeter.  Pick one up at Sears hardware for about $40.  Most of what you'll find are digital; they are very accurate and easy to use.
daze
Copper - Posts: 112
Posted: September 06, 2005 at 8:36 AM / IP Logged
O scope is the only way to go on setting gains.... meters are not acurate and the manufactures specs are always wrong !
Thats my 2 cents.... take it for what its worth!
Nothing can replace experience
meter for setting gains -- posted image.
