Remote start bypass for manual trans
jtf78
Member - Posts: 9
Posted: May 05, 2002 at 5:28 PM / IP Logged
Current I am installing a DEI 550 remote start sytem on a 2000 Civic 5 speed. I have it all installed and working but I wanted to put a safety on it so that if the owner tries to start the car in gear it would fail. I have heard of using pin switches on the gear shifter to do this but wanted to know if there is a better way.
Thanks,
Jerry
Jerry
haffer95
Posted: May 09, 2002 at 3:49 PM / IP Logged
compustar makes an add on that will work with dei products that is able to tell if the clutch is in gear or not
the12volt
Administrator - Posts: 3,955
Posted: May 09, 2002 at 4:03 PM / IP Logged
Hi Jerry, use the neutral safety wire. Look for either a BLACK/ Blue or Light Green wire at or near the fuse panel. To verify you have the correct lead, measure resistance to ground while in gear and in neutral.
the12volt
audio Xclusive
Member - Posts: 30
Posted: May 13, 2002 at 12:41 AM / IP Logged
is their a similar product that will work with crime stopper alarms
another Xclusive installation
Big Dog
Gold - Posts: 1,265
Posted: May 13, 2002 at 12:10 PM / IP Logged
Hey Jerry,
There is always risk involved when installing a remote starter made for automatics on a manual.  Serious injuries and/or death.  Accidents do happen so I hope you have deeep pockets if you get sued.  Myself I recommend you have the customer shell out a few bucks and buy a combo made for manuals,  in such cases I'd prefer to give him one at cost price if need be.  You'll sleep better! Remote start bypass for manual trans - Last Post -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
jmyinc
Copper - Posts: 59
Posted: May 18, 2002 at 1:11 PM / IP Logged
I used a small magnetic sensor from radio shack nd used some good epoxy and zipties to attach the magnet to my shifter cable and i just screwed the other to the car right under the magnet while in neutral. Works great. If you barely move the shifter the car also dies.
Morgan
-Morgan
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
