Inverting Subs
mmouse
Member - Posts: 6
Posted: August 08, 2005 at 12:29 PM / IP Logged
Is there any advantage/disadvantage to mounting a sub inverted? Is it purely for cosmetic effect? Just curious if anyone could share some info on this.
stevdart
Platinum - Posts: 5,816
Posted: August 08, 2005 at 12:58 PM / IP Logged
https://www.the12volt.com/installbay/search.asp?KW=inverted&SM=1&SI=TC&FM=2&OB=1&Submit=Start+Search
If you don't find all the info you need in those, use the search function and type in "inverted" and select "message body".
