93 Accord Tachometer
jrilla
Gold - Posts: 1,498
Posted: December 01, 2002 at 9:12 AM / IP Logged
After I installed a remote starter in a 93 Accord, I noticed the tachometer is not working.  I am assuming it is either the tach wire I hooked up, or the brain that is bad.  The starter works fine.  I will be able to troubleshoot it when this guy brings it back to me, but I thought I would just check real quick if someone had heard of this ever before.  Thanks
J Rilla
Owner/Installer
diabloed
Copper - Posts: 133
Posted: December 01, 2002 at 10:17 AM / IP Logged
First off i would double check that you are using the blue wire at the distributor and that it tests good with a DMM. Second i would see if the brain has a tach learn feature. And then  make sure that you are using the tach start instead of voltage sense. Let us know what you find out.
jrilla
Gold - Posts: 1,498
Posted: December 01, 2002 at 11:58 AM / IP Logged
Yeah everything checks out, The tachometer just works sporatically now.  I even disconnected the tach wire and the tachometer worked sometimes and then sometimes it didn't.  so it looks as though it is an independant problem.
J Rilla
Owner/Installer
Platinum - Posts: 12,488
Posted: December 01, 2002 at 1:36 PM / IP Logged
Was it working prior to you working on it ?
jrilla
Gold - Posts: 1,498
Posted: December 01, 2002 at 9:28 PM / IP Logged
Thats a good question, the owner never noticed it until I installed the starter.  It may have not worked before.
J Rilla
Owner/Installer
